Can you swap the output shaft and bevel gear from a 4wd 700 into a 2wd 700 to use in a kvf700?
Joebear · Registered Joined May 30, 2003 · 853 Posts Discussion Starter · #1 · 14 d ago Only show this user Can you swap the output shaft and bevel gear from a 4wd 700 into a 2wd 700 to use in a kvf700?
