Does any body know if a rear disk brake hub off of a mojave will work on a tecate I just picked up a basket case and it is missing the hub and rotor.
Not without some machine work.
Works fine on mine. Took a minute to figure out that I had a Mojo set up. Actually Mike figured it out in about 2 minutes when the T4 rotor I got from him wouldnt work. Dont know about the machine work. Mine already had the rotor and hub on the bike.
The problem with running he mojo stuff is that the rotor is a bit smaller in diameter, which means you have less surface area pad to disc. i have hubs here. several.
