I was out riding this past weekend. 300 miles in 3 days. The last day my temperature light came on. Checked the oil and coolant. Oil was fine. Coolant was low put some in it sucked it down inside and then light came on again this time it was leaking right at the mouth where I put it in, I let it cool down a bit drove again and now the reservoir is empty. It was raining pretty bad so i was not able to see where it was coming out of. But I am losing coolant. No coolant in the oil any ideas? Water Pump? Bad hose? I need ideas.
what kind of machine? you will have to take the covers off and see, other than the common areas (rad, hoses, and such) there is a drain at the bottom of the engine and if its coming from there its the "mechanical seal" in the engine
the covers around the rad
