Does the water temp light go on when you turn the key on and then go off when your motor starts up. My light never comes on but my fan does work, I was just wondering if my light is burned out. Thanks
you can check the bulb by grounding the little wire going to the temp sensor after unplugging it
The only warning light that comes on when I start mine is the oil pressure light until it starts. Temp light shouldn't come on when you turn on the key unless it's already over-heated.
