Throttle surges when turning
1080 Views 4 Replies 3 Participants Last post by  thamule
So here is whats going on. My throttle surges when I turn to the right. A little bit right is ok but the farther I turn the more gas the throttle is giving it. Started happening after I put new ODI grips on it. What do you guys think? The throttle is not catching on the grip either.
did you have to reposition the throttle for the grips? it could be pulling on the cable as you turn it. i had a moto-4 that did that. i had to adjust the throttle cable just a little bit.
im thinking that it needs to be adjusted. I just remembered that I replaced the handlebars when I changed the grips
not sure what you mean by this buts its been since last fall when I did all that. I have not gotten to ride much since then.
