1 - 15 of 15 Posts
Do all Kawi's have a hard throttle. been like that since day one . gives me heck on the trail. wears my hand out . I see all the V guys going to a honda throttle . is there a fix for brutes.
I dont think so my throttle is feather light
I don't have an issue but i remember seeing on a review on Youtube that the guy mentioned that the throttle could be a little softer.
I am wonderin if I took it and put some cable lube down it if that would help.
Why i ask the wife has suzuki and its so easy to hold for a long time
lube........
The lube in the cable might help..........but check the return springs at the carbs and make sure there is no restriction ......... then lube them well with grease.
do you have any pics? :)
Discussion Starter · #8 ·
yea but i dont know how to put them on here . they are before my snorks
lol sorry blue beast i should have been more specific, i was asking Wisconsin 700 if he had any pics of his set up. it would work the same for yours too :cool:
and which honda throttle did you use? 400ex/450r or trx90?
Pm me your e-mail addy and I'll send some to you. Otherwise I'll try to figure out how to post them here. Its from a 300ex, same as 400ex.
hey that looks really nice. i wish there was more room on the bars because thats where i'd like to keep the switch, but it looks like you put it in a good spot too. great mod :tup:
I figured it didn't really matter where the switch was because if you ain't in 4WD before you get stuck your screwed since you gotta be moving for it to switch anyways. The other place I had thought of mounting it was on the handguard mount. Thanks for the compliment pinkerton. Where u at in WI?
im located in dodgeville, about 45 minutes west of madison. where are you located?
1 - 15 of 15 Posts
