First of all I am new to this forum. Hello to all of you out there.
I have a 2008 Kaw. BF650. and no mods.
I am looking at getting two new rear tires since they are warn down and one is leaking. The front OEM tires are fine and plan to leave them alone.
I ride in South Carolina so this is my terrain.
10% to 20% water and light mud.
10% to 15% sand
and what ever else is left over is dirt, hard pack and asphalt. There are always rough trails, brush, small trees and logging roads that present puncture hazards.
I was thinking about the Big Horns but I hear a lot about the weight so I was going to switch to the Big horn 2's.
1 What is the weight diff.?
2 Is there something better I should be looking for a tire.
Thanks
Regardless what tire you choose, I would just go ahead and get an entire set. With your bike, I would opt for terra cross or the big horns, either one.
I have been reading the other posts on here and see a lot about both. the thing about the two front is that money is an issue somewhat and they are still in good condition.
You might check on here for someone who might have a pair of stockers they might sell cheap just a thought :tup:
I agree should get full set . If money is an issue might find someone close to ur area that has a factory pull off set u can buy so u can have more time to get what u want. you will also have more time to research for the best deal.
