OK, here is a tough one....
The rear cylinder has intermittent firing when at low RPMs. I can rev past it. I noticed this at St Anthony too so it is not related to the engine since this one is all new.
Things I checked.
I leaned out the idle, still did it, richened it, still did it.
Checked for spark. I took the spark cap off while the engine is running. You can see sparks jumping from the cap to the engine just like it should.
Just to be sure I swapped coils from rear to front. Same. Front runs super clean, rear barely fires at low RPM.
Re-set the valve clearance on rear jug. Same.
With the spark cap off the rear (only), the bike will start normally and run off the front cylinder alone.
With the cap off the front (only), Running only on the rear jug, I can get it to start if I try really hard and it will only run for a moment and die.
Things I checked.
