hey guys took some of the wires out of the bus connected there is 7 rows of 2 wires so 14 wires i believe, insted of soddeering i tryed using connectors with shrink wrap, well each row has 2 wires id cut those and connect and shrink wrap well i did all of them, went to start the brute and it wouldnt turn over, it would only turn over with the right brake pulled, so i would pull it then try to start it took forever to start then when started it blew a huge cloud of white smoke then ran for bout 5 seconds then shut off, then wont start unless i turn the key off and turn it back on, so i would turn it off and start it n it would run for 5 seconds then shut off.
HELP PLEASE!
ur supposed to solder all wires of like color together
allllll the color not matter if it has a line or not just blacks with balcks browns with browns white with whites????
