i know that you can swap the gears from a v to a brute for higher gear ratio, but do you have to give up the low gear in the brute when you swap them?
read somewhere that the european v force gears were even higher than the north american v gears, is that true or am i being BS'd?
also is it possible to install the stock high gear in a brute as the "low" gear and put the gears from a v into the "high" gear?
