Top speed in low range on my 2012 Teryx 4 is 31 mph. It looks like the 2014 Teryx is about the same.
I know the VFJ mod drops the belt down on the front and up on the driven pulley to give a lower gear. What is the top speed in low range with the VFJ mod?
My 2012 Teryx 4 does 50 mph at about 7,300 rpm. What is the rpm at 50 mph with the VFJ mod?
For my type of riding the stock engine performance is ok.
Vendor
I can get about 48 mph out of low gear. as to RPM when cruising, I have lighter weights in mine, so it's going to be higher. but at 65 mph I know i'm only turning about 7800 rpm with stock weights and spring I know I'd be less than that.
I haven't checked what I can cruise at for 50 mph.
Vendor
also, I think I was only seeing about 6800-6900 at 50 mph when it kicked in the speed limiter. However, the teryx 4 has much stiffer secondary and runs a stock primary spring of 10/220 (which is like my #2) so the RPM would be higher than the 2 seater 800 (which is a 4 seater with the back 2 seats turned into storage containers)
