Vendor
25.00 springs.
7 PRIMARY SPRING RATES AVAILABLE. (ill list the rates soon as I color code all of them) HIGH RATE OVER 200lb ZERO STALL SPRINGS!!!!!
1 ATV 4x4 secondary 26-28 inch tires (gray)
2 Teryx Secondary's (orange ones)
229.00 Adjustable Clutch kit. (YOUR CHOICE OF SPRINGS PENDING ON SETUP) No more underrevving from too high flyweigtht mass,
FULLY ADJUSTABLE RACE/TRAIL ATV WEIGHT KITS COMING SOON!!!!
JOhn
I'll take the three I said I wanted in the other thread.
I can come up this weekend if we don't go snowmobiling.
looking forward to seeing the spring rates posted.
how would that grey work for 29.5's?
I posted all the spring rates in another thread.
yes the silver would work for 28-29.5's 75%trail/25%mud. it's stiffer than the almond. but not as stiff as the red. the prob with the red is that it coilbinds. so you never get a full shiftout on the secondary.
this will be stiffer than the almond and provide better belt grip.
if you are doing serious mud with 29.5's or larger, then go with the EPI red.
how about some of those adjustable wts for the prairie. I should have never got rid of my Team ind, rooster wts. they worked great but i couldnt find the right setup. and know im feeling if i tuned the cvt on a dyno or had more time to play around with them.
