I’m about to do the crossover intake and 12 hole mod . What main jets do I need ? And where can I get some?
Sudco.com and jetsrus.com are two sites that sell jets for the Keihin CVKR32 carb. Sudco has a huge catalog online and I honestly don't know how to order from them beyond calling direct. I've ordered several times from Jets R Us using PayPal and the ship items out quickly. This is the page with the jets for the KFX 700:
KEIHIN ROUND MAIN JETS 99101-393 Jetsrus
This is what I came up with for the jet sizes based on the altitude ratios on the repair manual:
Front​
Rear​
Keihin part #​
Stock
#135​
#140​
019-192 & 019-194​
+1
#138​
#142​
019-193 & 019-195​
+2
#140​
#145​
019-194 & 019-196​
+3 (HMF full exhaust system recommendation)
#145​
#148​
019-196 & 019-197​
If you find it starts backfiring on deceleration after the mods and you need to go up on the pilot (slow) jet, the stock is #40. The attached image shows the part numbers for those. You usually only need to go up one or two sizes on the pilot jet to fix that issue.
start at front 184 and rear 186
then check plugs and jet down
buy 2 of each 180-186
ours ended up at 182 front and 184 rear
dmc duals, 12 hole mod, crossovers
Just installed a crossover intake a few months ago. You need to go bigger. The recommended size to me was to use a #43 size drill bit to drill the main jets big enough. Closest you can get with pre made jets is 230.
he needs a #14 and #13 drill bits or the jets 186-182
someone else's dyno run
I went to 185-185 needle 4th clip 40 pilot. it was perfect all the way thru!
51.40 RWHP
