Found a motor that I was thinking about buying. It is suppose to be all there. It had a gear go bad in the trans a couple of years ago the owner took the motor apart found the bad gear bought a new one but never reassembled. It supposably ran fine when the gear went bad. The power valves are great the bore and piston looks good. Also comes with stator, cdi, coil, carb, reed cage with carbon fiber reeds, radiator, shifter, kicker, fender mount from above motor and the case is not broken. Might be some other parts also but nothing that jumps out. Right now the guy is asking $400 I will try to talk him down. What is some thing like this worth? Or is it a waste of time thanks.
it's a good deal IF the gear that went bad is Not the one on the shaft behind the sprocket, very often when this gear goes, it takes the shaft with it and the shaft is no longer available.
rockhound if the shaft is bad how much are they if you have one?
