where can i get a stock brute timing key??
916 Views 1 Reply 2 Participants Last post by  speedy81304_KVF700
i need a stock timing key or so ive been told i need to revert back to stock since im doing my 840 build i lost or cannot find my stock timing key and honestly i didnt even install it so i really need two things where can i get a stock timing key at how do i install it back to stock i had the dealer put a 6* key in it..
dealer its a couple of bucks, plus you will need new left side engine case gaskets, and i would replace the water pump seal since you will be there anyway, you will also need a flywheel puller. its more of a time thing then a hard thing. to do
