Still learning about my Mule and getting ready to add some accessories. Last night I was looking in the front compartment with a flashlight and found a couple open wire ends I hadn't seen before! I had to reach around the wire panel and push/pull them through the hole in the top/center of it. These two wires are designated as "Accessory Terminals Front" in the wiring diagram. One wire is Black/Yellow (Ground) and the other one is Brown/Red which is 12V @ Ignition on from Fuse Box 1, Fuse #3, 15A, the Accessory Fuse (Front).
Because it was just dumb luck that helped me find them and, I have never heard anyone mention them, I thought I'd do another version of the Wiring Diagram adding the locations where Kawasaki put wire ends that we can use to connect accessories. This should be of some help to newbies like me that don't have someone nearby that can point out these locations. :laugh:
Cheers,
Cheers,
