Depending on what size you are getting it is pretty straight forward.You will have two cable going from the battery to the relay.Then two cables from the relay to the winch.Two wires going from the relay to the switch and finally a power wire the the switch.If you are getting a 2000 lb. or smaller there usually isn't a relay just two cables from battery to switch and two from switch to winch.
