1 - 9 of 9 Posts
hi fellow riders,
Tim with Wolfsnout here.
We are out riding this weekend, upon our return we will be posting some info about our unique products. It was 91 degrees today and the red clay is as thick as usual.
Take a look at our site http://www.wolfsnout.com or ask me any question you like. Hope you are having as much fun riding this weekend as I am.
Wolfsnout ATV riding / racing mask
Hey guys, just wanted to let you all know a little more about why our products are the best choice in an atv or utv dust mask.
The Wolfsnout Pro Race Series and the Wolfsnout All Sport, are the best dust protection for the hot dusty season. I know you will see, as you learn more about our products, that we have invented a great new innovative method for dust control. The one thing that makes our products stand apart from others is that they were designed for off road motorsports, and only off road motorsports. We started with the perfect material which is easy to breathe thru and does not trap heat, yet, is very affective at filtering fine particles; it is specifically designed this way to allow for breathability at a fast paced breath and you are never breathing in your exhaled air. It’s actually not too hot to use in 90+ temps. We believe it is the mask of choice for use in the summer, when it is the dustiest. This Utv dust mask is washable and reusable, no filters to buy and throw away.
The Wolfsnout Pro Race Series is a conical shaped device, which adaptively conforms to the inner confines of the front of your full face helmet. No strings or straps to place around your head, its light weight design allows it to stay in place simply by creating a slight pressure between your face and your chin guard. A really cool by product of that, is you’re not trapped in it until you take your helmet off. It can be removed and replaced in seconds as needed, without removing your helmet.
The Wolfsnouts are designed specifically to work perfectly with goggles, that is why the filter only covers the bottom of your nose, so your goggles will not cause uncomfortable pressure on the top of your nose. This was one of the first annoying concerns we addressed in early development. We knew most people would not wear the mask if it caused discomfort to the top of your nose. This feature also prevents goggle fog and will not obstruct the seal of your goggles in any way. Dust inside of your goggles makes for a bad day. Just one more thing that puts our product above the rest. The comfort level is amazing.
The All Sport is of the same design as the original Wolfsnout Pro Race Series, only it has a flattened front with multiple layers in all the right places, to filter the incoming air as it forces exhaled air out the bottom and sides. The All Sport has a strap to hold it comfortably in place. While this mask is not a versatile as the Pro Race Series, it does work with ANY style helmet.
I personally prefer the Pro Race Series when using a full face helmet, but often use the All Sport when goofing around without a helmet.
One more thing to keep in mind, you can drink from your hydration pack or a water bottle straw, without removing these masks. That’s a big plus if you race!
Remember, the Wolfsnout will not starve a fast paced breath!
I will be happy to answer any questions about these features.
I have two of the Pro Race series style but haven't ever used them yet. Kinda of just decided I don't really like riding really dusty trails. They seem like they would work decent but I just don't see myself using them.
Not riding in the dust at all beats Any Dust Mask!!! Where I ride thats not a option, unless you ride in the mud and rain. :)
No dust on the sand dunes. :tup:
One more good point..
Both the All Sport and the Pro Race Series Wolfsnouts are hand washable! Simply wash in a mild hand soap, and hang dry! No filters to purchase.
Email we received, just the other day.
Hi Tim,
Just wanted to touch base with you and give you my thanks for such a great product!
While pre-running for the 2010 Baja 1000, I had a little mishap that left me feeling like I got kicked in the chest by a Mexican Mule. When I picked the bike up off the ground, it was obvious that I had sustained some type of injury. It was difficult to catch my breath just trying to lift the 450 KTM that I was riding. We assumed that I had probably bruised a rib and I was good enough to continue the remaining 30 or so miles. As it turns out, I had broken 3 ribs and bruised a few others!
I firmly believe that I would not have been able to make those 30 miles back to the chase crew if I had to deal with "concrete" lung on top of my injury. The Wolfsnout [All Sport] filtered the fine desert dust [that at times decreased visibility to only a couple of feet] clouds allowing me to breath cleanly. I have been riding/racing dirtbikes for 30yrs and have been happy to eliminate the heavy breathing that we all suffer from when riding in dusty dry conditions thanks to your product. Many people have asked me"does it make you hot?", I reply with, "I didn't even know I was wearing it while riding in the BAJA desert heat". I normally ride in the South Easern woods wher it gets hot, humid and sticky and I have no issues or discomfort with it. When you stop after a long run, you do notice it a little, no big deal though. I just pull it out of the way and push it back in place before starting out again. You really do forget that you are wearing it after about 2nd gear.
I value my Wolfsnout as much as my steering stabilizer and wear it on every ride, even while cutting the grass!
Thanks
Vince C
Team DBBL 2010 Tecate Baja 1000
S.O.R.C.S.
AMA
1 - 9 of 9 Posts
