1 - 20 of 49 Posts
OK wot kind of mods i can do it at home with out any spacial parts to bay
and than you guys you are the best i love this forum you are the BEST
12 Hole mod -- requires 1" hole saw
Polish your carb slides
Trim your carb springs
Jet your carb -- about $15 in jets
Plug Boot Mod -- around $13 in parts
Carb coolant hose removal -- you need a few vaccuum caps
Crossover Intakes -- some copper tubing and some windshield silicone approx $20
EPI Pink primary spring -- $20
That will get you started.
Those are some of the free/cheap things you can do.
Thats the beauty of these machines, the homebrew mods that WORK!
Do a search for each of these mods in this forum. It should keep you busy this weekend. :D
12 hole mod -- requires a 1" hole saw------------got custom box pics below
Polish your slides ------------------------------- how
Trim your springs--------------------------------don
Jet it correctly about $1[/QUOTE]----------------????
Jet it correctly How ?? can you explain ????
and if you have some pics pleas that will be grate
thank you so match
With that custom air box the only way to get your jetting right is with an air/fuel meter.
With the 12 hole, its been done over and over. With a list of your mods and altitude someone here can jet you close to where you should be.
Perform a search on this and all your questions will be answered.
Also, check out Kawasaki KFX 700 V-Force Page for some how-to's.
Discussion Starter #6
how can i find out whot kind of jets do i need (size)
and is the auto parts store have them or not ?
Sam---If you're going to do various DIY mods---Put up a sig showing what year V what you've done so far etc. Makes it much easier for the guys to help you.
Kenny
Discussion Starter #9
Kenny
It is 2006 KFX700
12 hole mod -- requires a 1" hole saw------------got custom box pics are on top of this thread
needle shim with #4-----------------------------don
Polish your slides ------------------------------- don
Trim your springs (1 ring) ------------------------don
Crossover Intakes ------------------------------ don
Plug Boot Mod -----------------------???? any one have pics for it
Jet it correctly ------ ----------------????
can i get the correct jets in auto or bike store ? or dialer only?
or can i just drill them out ????? if yes can you tell me how
Post #7 gives you a link of some for sale on here---Good deal---Your doing so many things so fast---It's hard to say what you need---You would have needed 180-185 jets but now you've done the crossover mod---So yes you'll need bigger---Drilled probably at 7/64---Hope it all comes together smoothly for you.
Kenny
with that air box u will probably need larger than 5/64 (kiehin 200), 3/32 may do it. theres a drill bit n jet conversion chart. with crossovers u also need larger pilot jets. most use 42's u may need larger as well due to your airbox. itll be intresting to see what that airbox does over the 12 hole. also cut the baffle out the airbox if u already havent.
Kenny
It is 2006 KFX700
You can get the wires and boots from ven.
ATV Trick Stuff, Trickest stuff for your atv.
Discussion Starter #14 (Edited)
with that air box u will probably need larger than 5/64 (Khan 200), 3/32 may do it. theres a drill bit n jet conversion chart. with crossovers u also need larger pilot jets. most use W's u may need larger as well due to your air box. it'll be interesting to see what that airbox does over the 12 hole. also cut the baffle out the airbox if u already havent.
OK so wot do i need is 3/32 drill bit and drill it out the main jets ????
pilot jets 42 ???? can i make them or i have to get them ????
and wot do you mean by mean cut the baffle out the airbox ?????
is it some special area on the airbox or just another opening
and I'm planing to build custom dual exhaust do i have to redo avery think again ?????
don get me wrong guys I'm not cheap i just like to make staff but some times i have to bay
it is more fun when you custom make some thing instead of baying premed
When you do the 12 hole mod, you end up plugging the origional intake, inside the arir box you will see a baffle towards the front of the inside of the air box. sinply cut it down so that the 12 hole can work the best with out impeding air flow. I used needle nose and broke a little at a time, but a dremmill tool would do a cleaner job. Here is a pic of a 12 hole mod, you can see also that they plugged the old intake.
Discussion Starter #16
yes i did same thing on my box to i plugged in the original intake hole
so all my air is going from the top of the box all the small out linens
removed on the bottom of the box except the engine breather
Discussion Starter #17
so any one else
put bungs on your custom pipes for sure---With custom air flow and custom pipes and mufflers---There is no standard to follow--You'll have to tune by A/F readings.
Every time you post you've got a new idea---Hard guy to keep up with:p:p
Kenny
Discussion Starter #19
Kenny
hey Kenny lets forgot about the pipes with all the mods that i got now wot do i need to do how match do i need to drilled out my jets ?????
1 - 20 of 49 Posts
