61 - 80 of 87 Posts
Ray plain english :blink: :blink: :blink: :blink:
So is it better to run w/o a box or lid
Let me put it this way, the more air and fuel, at the correct ratio, you can put to an engine the more power it will make. The down side is, the more you unrestrict it, the more sensitive the jetting will be to temp and pressure changes. It's sounds like Bartlette has a setup that works. I will also say that with a stk or lightly modded engine, it is very hard to get enough fuel through the carbs to run an open filter. So if this is the setup you want, it's probably well worth the money for the testing that Bartlette put into this.
One more thing, the more you do to the engine, the more fuel you will push through the same jets, ie: more displacment, higher compression, better heads will pull more air through the same carbs in the same amount of time, thus you have a higher velocity and a greater pressure drop= more fuel.
Thats why we have to run stk needles in our 80+ HP engines, the Dyna needles are way to rich, but are great on a stk or light mod engine.
Thanks,
Ray
Thanks,
Ray
Why not just raise the clip a notch or two? Why wouldn’t that work? Just curious as I run Dyna needles. :huh:
Originally posted by Dynoray@Mar 1 2005, 08:12 PM
Hi Ckedd, they are just the wrong taper for a big motor. Work great on a stk or light mod engine though.
Ray
Ok, I will have to test that both ways.
Thanks,
Ray
Ray much better , Thanks :p :D
if 175 main jets are the biggest you can run what would be the biggest dynojet mains to run.what is slight engine mods?can you run stock carbs on the 730 kit its in my future.
Hi Treemasher, you can run bigger then 175 mains, but when you get much bigger, the needle/nozzle becomes the limiting factor so you don't gain much more fuel when you go bigger.
Yes the stk carbs work fine on any engine, just limit you to about 85 HP on pump gas with our 730.
Thanks,
Ray
Now, I found a little different.
on Rocket Joe's he had Mikuni 200's front and back. and was peaking out at 16-1 on the A/f ratio which was lean.
We drilled them 5/32nds and it went to 15-1.
and eventually went to 1/8th inch drilled jets and it was about 14-1.
but 175's in the mains you can still go bigger and see an improvment./
that is what I've seen.
I am going to get another Dyno in the next couple of weeks just for Atv's and street bikes.
So we will be doing alot more Atv testing than we do already.
I Also have a Vid of a 690 RWHP Turbo Hayabusa on one of the Mobile test Dyno's.
You can actually see the chain stretch in slow motion.
How can I post it.
John.
That's about what we found John, once you go past 175-185 mains, you gain alittle but not much, ie: dtrilling to 1/8 to gain a little. We usually just run 200/198's on bigger engines and adjust the airbox to match.
WOW 690RWHP, that is awsome, can you imagine driving that!!!
Look forward to that video.
Thanks,
Ray
where can I host a video at.
I would like to show it.
I have it at the shop on the dyno Cpu and can e-mail it or transfer it somehow.
690 Rwhp and 335 RwTq on a stock rear tire.
on the street it can hit 200 in about 8 seconds.
It only has a +6 swingarm with stock rake and frame.
Just the heavy duty output shaft and stock 1299CC bore.
Truly unbelievable. until you see it.
Let me know how.
How many meg's is the file John.
My house and shop are both out side of town so all 6 computers are on dial up (SLOW)
If it's only a couple of megs, you can E mail it to me and I can post it.
Thanks,
Ray
Originally posted by VFORCEJOHN@May 6 2005, 10:48 PM
someone had a website that you could view vids on what is the website.
hey vforcejohn,
Yeah I found that site awhile back. It works for some but not for others..
anyway here it is, very simple to use:
www.putfile.com
no warranties expressed or implied...
congrats on the new atv dyno, good to see you getting *even* more involved in atv tuning.
Dave
61 - 80 of 87 Posts
