knocking noise 750 brute
5.2K views 7 replies 4 participants last post by  WoodBoy
#1 ·
im hearing a knocking noise on right side of engine
when cold start you hear it .when engine gets hot
it goes away.it sounds like it coming from inside where
the belt is
any help any body.
#5 ·
Get a puller to remove the primary clutch. Remove the clutch and the belt,then run the engine,if the noise goes away,you know it's a clutch problem if it doesn't you have a bad crank bearing.
