Pictures - Swingarm bearing replacement
2 reading
5.4K views 17 replies 12 participants last post by  morehorsepower
#1 ·
Finally had a little time this past weekend to put the pictures together. There are quite a few so I cropped them down from around 150k to 30k so it'll load faster.
Swingarm Bearing Installation
I recommend anyone who rides in water to go ahead and change the bearings before you have half your day ruined as I did. I had no warning signs that this was about to happen. We were blasting uphill wide open jumping rain ditches as we went. By the time I got to the top, the right side bearing had disintegrated. The left side looked like this when I got it out.
#3 ·
Nice thanks for that I did that recently but didn't get pic's, I didn't put those grease fittings on but I think that I will now mine were dry as crap, any more you can tell us about thos grease fittings?
#4 ·
Excellent How-to, Kevin! Thanks for posting. I hate that this bike doesn't have any grease fittings on it. While bleeding my front brakes tonight I was thinking that there needed to be zerks on the top and bottom of the front spindle, and on the a-arm pivots. and on the steering stem, and the.....on and on.....
Did you use anything to seal that freeze plug? I've got bearings on order, I would like to install the freeze plugs and zerks when i do mine.
#9 ·
V800 - Nothing special about the grease fittings, you can buy a package of them at Advance.
Bandaman - Freeze plugs are a tight fit, I don't see anything getting by them.
Eyedoc - You can link from the spring chart that is pinned
Docpoof - if your bearings look as bad as mine did, you're going to want to new races also. You can put a socket in through the hole where the driveshaft goes and then insert a long extension into the socket. Place the socket end against the race from behind and tap the extension with a hammer and the race will pop out.
#11 ·
This is why I joined this site, for info like this...Thanks Kevin.
#12 ·
im blasting the "V" by this weekend, paint by sunda or monday i hope. now that the swingarm is out it'll be a great time to do it on mine to. man did mine look like smurf!!! what a crap design!!!
#13 ·
Awesome step by step instructions. Next time I replace mine, I may just go ahead and do it myself. Thank you for posting them!
#14 ·
yo kevin... i tried a 35.22mm freeze plug. way too big i'll check monday if another sixe is better. there couldn't be more than one size swing arm, could there? <_< <_<
