I had to buy a longer wire to go from the battery compartment to the front hood area of the mule. I made my own wires using lugs that I purchased also. (I ran the wire under the mule along the framing along side the other wires). I put my winch solenoid in the under hood area also. I ran the positive wire from the battery (coming off a 100 amp breaker I installed in the battery compartment), to the hood area to one side of my new solenoid that powers my new fuse box, winch positive wire comes off of that solenoid to the winch solenoid. To trip the winch solenoid and the one that I am using for my fuse box, I tapped one of the LED headlight wires. Just remove the push pins on the dash, unscrew the one screw holding the gear shift rubber knob on, remove it, then remove the three gauge cluster/screen screws, this allows you to remove the dash and get to the wires you need to tap into easier. You will need to unplug the wiring harness connectors from the dash rocker switches also, they just have tab you bend back and then they pull off. Label them first!! I just connected another set of wires to the wires feeding the dash rocker switches to connect to the solenoids to open/close it (power on/off). But from what I remember there may be a set of wires that are hot when the ignition turns on but were not in use that I used also?? I know there is a set for the factory horn, but I don't think that is the one I tapped into. Just find a set that gets hot when the ignition is hot.
