When removing the rear swing arm to re-do the bearings. Is it a must to drain it first if all you are doing is putting in the "new" sets. And must you undo everything and pull the swing arm out and away or can you just drop it, and replace. I looked at Kevin's site to see how to begin and it seems pretty easy. I just was not doing the drilling and tapping I was just going to do the bearings and check out the brakes.
Also Has anyone ever changed the rear brakes in their V? A buddy of mine who works at a dealer says no one ever has changed a set of rear pads but me. Ever! They according to him don't wear out! I've had rear brake issues since day one with mine and it went back the first week for that and front wheels they hopped bad so bad you could not go over 50 on tar. They would just shake you loose.
