So i recently replaced the carbs float needle and gasket as it was leaking badly after that I had no leaks.. when I go to start it the atv it will instantly rev to the moon I can’t get it to go down it revs badly I have to shut it off right away I’ve checked my adjuster for the gas and all those little things and no luck.. could I of maybe messed up the throttle cable?
